ron3033
ron3033
Hello
I am a new joiner and I want to set an avatar before I post to ask some advice about my system.
i went to the User CP....Edit Avatar..... I can not turn off the little green dot about no avatar. I have one on my flash drive I want to use.
I am sure i am just missing some little step. Any help appreciated. By the way this is a great site!
Thanks
Ron3033
Alex2507
Alex2507
You probably need like 5 posts before you can use an avatar.
AVRat
AVRat
Alex may be right, but did you try selecting the Custom Avatar radio button which would deselect the No Avatar button.
ron3033
ron3033
It must be, and this will be my 5th post. Thanks. :)
Yep, it is 5 posts. Give it a few minutes to register too,( your 5th post) because right after your 5th post it still wont go. Good luck
Ron3033
