Thanks for the responses. As a newbie, I really appreciate you guys taking time towards a common passion.
I am pretty much sure the AVR pre out voltage is not a deciding factor as the amps gain will suffice. As I really like my 860 and the way it plays with the sonics, I will continue to purchase Yamahas. So it is 3080 then!
This is that time of the year where 3080 is already 8-9 months into the market. If I go for it, should I get a new one from BB or Crutchfield or is it safe to get a refurb from A4L. The latter sells it $400 below what the priors are selling it for. I am sure many here have opinions on getting a refurb, but do you think its fine?
And also, I am guessing the release of newer models from Yamaha are right around the corner, is it May?! Should I wait for the feature set and see if they are good, and then decide to get a 3080? Or get 3080 asap
