Hello,
I have 2 RSL Speedwoofer subs and a Denon 3600h AVR. Currently 1 sub is connected to sub pre-out 1 with an RCA cable while the other is connected via the RSL Bluetooth adapter in the second sub pre-out. I recently learned I can connect both subs using the single RSL bluetooth adapter which opens up lots possibilities for placement of the subs. So here is my question. If I connect both subs using Bluetooth with the single Bluetooth adapter, will Audyssey treat the subs as two subs or as one sub when I run the room correction program? I’m not sure moving my sub to a better location is worth trading off the treatment of two subs for correction versus a single sub, even though I have two subs. Does that make sense?
