Yes Rat will read the .ady files, in the owner's thread, I had included the screenshots as read by Rat.
I did too, but this one one of those major misconceptions of the century. For a long time, people, including me, have assumed
incorrectly that Audyssey would enforce a dip (so called BBC dip) unless you disable the feature, and until the App there was no such user option.
The fact is, as clarified in a couple of recent Youtube videos, Audyssey and Denon clearly explained that Audyssey's MRC would result in (not create) such a dip if your speakers were designed to have that dip. So depending on your speakers you may or may not see that dip. Still, even if your speakers are not designed to have the BBC dip, you should still disable MRC with the App just to be sure, though again, even if you don't, you won't have the dip as long as the speakers was designed not to have it, and was designed properly. In the video, the Denon rep seemed to suggest that you should use REW to find out if your speakers were designed for the dip, and they were, then keep MRC enable, in order to preserve the designed dip. To me, it is up the user, if he prefer not to have the dip regardless, then it really isn't wrong to let Audyssey flatten it out.
Audyssey failed badly on this count, as I know there are people who hate the MRC and that might have been the only reason they avoided D+M's or won't use Audyssey regardless, without knowing the fact that they wouldn't have the dip anyway if their speakers weren't designed to have it in the first place.
If you have the room for it, go for 7.1.4, imo it is much better.
Now that you have time, there is a lot more to play with the App.
I think you should, why not?
There are tons of info on AVSF, but I also did start the MultEQ Editor App users thread right here on Audioholics, to share hints/methods etc among users, so take a look over there if you are interested.
