Audyssey just for speaker distances/delay?
Pogre
Pogre
No, I don't think it ever sounded good. The Yamaha I had sounded good. I just don't like the sterile sound of the Denon. Yamaha seems to have a more lively sound of that makes sense. Denon is kind of full maybe you could say. The Denon just isn't jiving with me or my speakers. I have Def Tech SM 65 LCR and SM 55 surrounds if that helps any.
I've had both and they sounded identical to me in direct mode. After setup I MUCH preferred Audyssey XT32 over YPAO. To hear you describe it, it sounds like something is wrong. I'm wondering if you have an issue with setup?
Pogre
Pogre
Ok I just ran Audyssey again and I only moved the mic to the left and right about 5-10 inches. I left it in MLP for in front and I put the mic on the back of the couch to the left and right. It sounds fantastic! I'm like beyond surprised here. I must have really screwed the whole thing up when I ran it the first time. I have it on reference and I'm loving it.
My friend told me you can leave the mic in the same position for so 8 tests? True? I'm gonna get a tripod and try that.
Ah, there we go! Glad you got it sorted. I was gonna open my menus and run you through a couple of things.
Hetfield
Hey thanks guys for all the help. I'm still evaluating but so far everything sounds great. I'm liking this very much now. I'm pretty sure things didn't go perfectly too because my dog did bark one during one of the tests. I'm gonna buy a tripod and the next time the kid is out with his mom and it's real quiet I'm gonna run Audyssey again.
Now does anyone use dynamic EQ and if so what setting and do you use dynamic volume and if so what setting? I was told not to use it with Blu Ray but with DTV Now/cable it's ok? Thanks again.
ParisB
I'm mostly movies, and definitely prefer DEQ. The faq cover this extensively, I can elaborate later too.
Check out the thread on bass/subwoofer calibration and Audyssey by mike thomas over at avsforum. Very detailed.
Trell
Trell
I'm using DEQ but uses different Reference Level Offsets (RLO) depending on the material. For movies I use 0, TV I use -10 and for music -10 as well, but for some material I turn off DEQ or change RLO to my liking on-the-fly.
For this a Harmony remote is quite useful for me as QuickSelect on the Denon can store various settings, including RLO, and starting a Harmony activity will also recall the appropriate QuickSelect.
Pogre
Pogre
I love DEQ and prefer the flat setting. I float back and forth on the -Reference Level Offset between 0, 5 or 10, depending on what I'm listening to.
*Edit: I leave the dynamic volume setting and LFC off. I think they both choke the sound so it doesn't carry into the next room or neighbors house.
Are you not supposed to use Audyssey with 5.1 music? I'm listening to 5.1 music now and it sounds fantastic. Wow I'm blown away and intrigued here.
Absolutely, I definitely prefer to use it with 5.1(SACD) and 7.1(for example, Blue Ray Live concerts) music.
I guess the moral of the story is you can mess up Audyssey easy if you're not careful and it will make your system sound like poop.
Oh yes, you can really mess things up if not done right. There is a pretty good detailed guide here, but it doesn't look like you want to spend much time studying and following it to the letter.
https://www.willowville.net/ht/Audyssey Setup Guide.pdf
So if you just want to do a quick one, you can simply follow the onscreen instructions but pay attention to the following:
1. Disable any EQ on your subwoofer, if you can't disable it, set to low pass filter to maximum, phase to 0.
2. Set the subwoofer volume to 9:00 am position to start, if Audyssey auto setup ask you to turn it up, try 10:00 am or higher until the onscreen meter turns green.
I think the onscreen instructions do cover the above, but I included it just in case.
2. Normally one should use all 8 positions for the best results, but if your setup, I think you should do just 5 positions because you don't have enough space between the couch and the back wall. Below are some tips for better results:
- Be sure the mic is at ear height, but for high back couch, set it at least 2 inches above the highest point of the couch back.
- Turn the HVAC system off, the room needs to be reasonably quiet. Stop for planes and other traffic noises.
- MLP (main listening position, presumably the center of the middle seat of your couch.
- 12 inches from the MLP to the left and to the right. (That's positions 1 through 3)
- 10-12 inches to the front of the left seat.
- 10-12 inches to the front of the right seat.
So again, a total of 5 positions.
3. When you are done, do the following first, you can always experiment with other settings later.
a) Disable dynamic volume.
b) Enable dynamic EQ (Set the offset to 0 for movies, 10 for everything else (to start with and play later..)
c) Regardless of what Audyssey set the crossover points to, change them all to 80 Hz.
d) Increase the subwoofer level by 3 dB (try 5 if 3 isn't enough for you).
e) Select Audyssey reference, only try flat if your room is small. Reference should sound "warmer".
Step 3) above is very important, based on your apparent complain about the "Denon neutral"/unexciting sound!!
There is an Editor App that you can purchase at the Google store (Android),or Apple store (IOS)
https://apps.apple.com/us/app/audyssey-multeq-editor-app/id1210584625
https://play.google.com/store/apps/details?id=com.dmholdings.AudysseyMultEq&hl=en_CA
For $20, it is highly recommended, as it gives you more controls, such as:
- Modify the target curve to you liking.
- Disable the Mid range dip that many people hate.
- Limit EQ to your room transition frequency, typically between 200-300 Hz depending on room dimensions.
- Store multiple target curves so you can try different ones, without re-running Audyssey setup.
All of the above are intended to help in case you need to do it again. Since you said it sounded good to you now, it is best to leave it alone, but please do pay attention to step 3 (highlighted red) and try those settings.
By the way, @AcuDefTechGuy has experience with a few Denon AVR, even their flagship AVP. He now would typically recommend Yamaha's, but mainly because of their better reliability record. Like me, he will also tell you it is DSP (Digital signal processing) and REQ (Room EQ, that is, Audyssey vs YPAO) that make them sound different. In direct/pure direct modes, one won't sound warmer or colder than the other.
If you do end up replacing your X3400H with a Yamaha, I would recommend nothing below the RX-A1080.
I never use Dynamic Volume myself but if you have kids it might be appropriate for late night listening....
Pogre
Pogre
I'll echo what @lovinthehd mentioned earlier too, and that's to do all of the available room measurements. Like said, the more info the better. Do them at ear level and follow the pattern it shows you on the screen for mic placement. I do all 8 around my main seat and it does a good job.
Hetfield
So some of you guys use flat instead of reference? Interesting, I may try that.
I think I'll leave the dynamic volume and all that off for not. See how things go. I don't like compressing the sound in general.
Pogre
Pogre
I think reference tapers the highest and lowest frequencies just a tad. To me it sounds slightly brighter flat and that's how I like it, ymmv.
Hetfield
Wow in learning a lot here, thanks guys. I'm now going to watch a movie I watched this morning before I re did Audyssey and see either I hear a different. It's an old one, back to the future.
As mentioned, dynamic volume could be useful for late night listening especially if you have hard time hearing the dialog.
Dynamic EQ is a different story, you really should have it on and experiment on the offset setting. 0 is most suitable for movies, 10 would likely be better for music. If you normally listen loud, say with volume near 0, then Dynamic EQ should have very little effect, anything below 0, I bet (can almost guarantee!!) you will like it on.
Trell
Trell
I use Dynamic Volume when watching cable, which I do very seldom nowadays, to lessen the annoying impact of commercials.
I have cut off the cable/sat stuff to avoid commercials as much as possible :) If I had to watch a show with commercials it would be with a dvr so I could skip thru them....
Hetfield
Ok guys guess what dynamic EQ was on I guess when you do Audyssey it auto turns it on and I didn't notice. It was at 0 and I'm trying it at 10. Ok gonna turn Back to the future in a sec just to compare to this morning. Yeah I'm on vacation this week and bored.
Some Audyssey avrs automatically turn on not only DEQ but also Dynamic Volume, so you just have to change things as needed.
