AudioControl Concert XR-6S (8K 9.1.6 Immersive AV Receiver with Zone 2 and Class AB Amplification).
Now I'm not 100% sure on this whether Sonetto II G2 is the actual reason behind such strange crackling sound from JBL 625C or it's something else?
When I connect this JBL 625C into the Front Right connector behind the A/V receiver, I don’t hear crackling sound anymore, atleast from what I have observed after playing songs on YouTube or watch couple of movies on Disney+ Hotstar.
That is a good troubleshooting step obviously, but you should also try connecting the cheapest speaker you have to the center channel and see if you get the crackling, don't do that with you more expensive speakers.
It is also possible that you have a bad/loose banana connector, or as you mentioned, something wrong at the connection for the center channel inside the receiver.
Would all of you have any idea about this issue & how to fix it?
You need to complete your troubleshooting steps to determine the cause first, before talking about fixing it.
I am interested to purchase Marantz Cinema 50 & a 2 channel Power Amp RB-1552 MkII from Rotel Audio.
I want to power the front Sonetto II G2 Left + Right power hungry demanding speakers using this Rotel Audio Power Amp (2 x 130 Watts) while the centre speaker & all others will be powered by Cinema 50.
By this means, all the connected speakers into this A/V receiver & Rotel 2-channels Power Amp, should receive their rights of appropriate power so as to give me a detailed most cleaned sound quality. What are your thoughts on it?
As mentioned before, those low output Rotel amps is not going to help much, if you want to get the best out of those very nice Sonus Faber speakers, do them a favor, get an amp rated at least 250 W rated into 4 ohms, such as those class D amps recommended before.
Also, the center channel usually demand as much or more than the front left/right channels do for many movie tracks. So you may want to consider a 3 channel amp or a 2 channel one plus a monblock for the center.
The Marantz Cinema 50 is a fine AVR, same as the AVR-X3800H, almost identical except for the aesthetic so if price is right, go for it.
Also there are 2 connectors behind JBL 660P Subwoofer. I noticed when I insert the Sub-woofer Nedis Audio cable into the white connector, the Subwoofer doesn’t output sound nor does it sound under the Test tone in Yamaha RX-V685 A/V receiver’s setup. However, if I insert the same audio cable into the Red connector, I can hear Sub-woofer boom boom sound & works under Test tone as well but the problem is that earlier, it’s bass impact was too good but now, I have to take the A/V receiver’s volume level all the way to -5 to -3 to hear it’s sound under the Receiver’s test tone in setup.
There are usually 2 options, a) if you connect the subwoofer to the LFE (subout) of the AVR, you would use one connector, not sure if it should be the red or white, probably the red if you are getting sound there, or b) if you connect the subwoofer to the pre out of the Yamaha, such as the front left/right then you would use the other connector. If the JBL manual does not say that clearly then you will to just try different ways to find out what it is. Again, it is likely that the red terminal would be the one to use for connection to the sub out of the AVR.
Also earlier even at -32, the punchy effect of JBL 660P Sub was quite good but now, I have to take the volume level all the way to -23 to feel the same effect. I strongly feel after the crackling sound of JBL 625C Center channel, the sub-woofer’s punchy sound has also been reduced.
Did you make any other changes that could affect the level of the subwoofer? Such as, re-running YPAO?
Any help or guidance here will be much appreciable as I am totally clueless at this point whether the issue is with:
a) The Power Hungry Sonus Faber Sonetto II G2 Bookshelf speakers of 4 Ohms
or
b) The A/V receiver is of entry level not being able to meet the power demand of all the connected speakers.
or
c) The Center Channel connector at the back of Yamaha A/V receiver.
or
d) JBL 625C itself.
All of those factors you mentioned are the possible cause(s), the entry level AVR is definitely only suitable for use with those Sonus speakers if you don't listen loud, sitting close to them such as less than 10 feet (even 6-8 ft better). And again the Rotel amp you pick won't help much, but a little for sure.
apoorvasheth
Hello Peng,
Thank you for your response.
The concern with Class D Power Amp is that if it’s above 200 watts then chances are that it might overpower my other speakers - JBL 630/625C & S.F. Aster which are of 150 & 125 Watts. Even Sonetto II G2 is of 200 watts.
So in this case, the only option I have is Rotel Power Amps mentioned above as they offer pure 120 watts but yes, my Sonetto II G2 being of 200 watts, it will fall short of 80 watts which means it will not be driven to it’s fullest.
The banana plugs used for the Center Channel are of ProfiGold that’s of very good quality & fits perfectly inside the Center Channel connector behind this A/V receiver.
I saw you had previously suggested either Anthem AVM90 or the Marantz AV10 but they are way beyond expensive. I better buy a nice car for that price.
So, please suggest me a good Power Amp which offers atleast 140 to 150 Watts & is 5 channels driven b’coz I would like to drive all except the Surrounds via an external Power Amp & leave the Surrounds JBL 630 to the new A/V receiver to drive completely.
Just a question here, can my Dolby Atmos speaker - Sonus Faber Aster on the Ceiling be driven by Power Amp or just Front & Surrounds speakers be driven by a Power Amp?
The reason I want to drive the Aster with Power Amp is b’coz I am unable to feel the Dolby Atmos effect & that’s possibly b’coz my Yamaha RX-V685 A/V receiver is of an entry level & unable to meet power demand from all 7 speakers.
So, driving the overhead Aster Atmos speaker via a Power amp will definitely get me a pure Atmos feeling experience, what’s your suggestion on this?
The back of my Yamaha A/V receiver has Sub 1 & Sub 2 under Pre-out & I think previously, I used to connect the Nedis audio cable into the white connector behind this JBL 660P but now since it doesn’t function, I have to use the Red one which isn’t giving out that deep impactful bass even at lower volumes like I used to get before when the Nedis audio cable was plugged into the white connector I guess of the JBL 660P.
Also this Yamaha A/V receiver that I had handed over to their authorised service center last Saturday to have them check the Center Channel connector issue due to those sudden frightening crackling sound from JBL 625C, just checked with the service center team yesterday & they couldn’t find any such fault.
When I was at their service center, I noticed they use some simple low priced kind of Bookshelf type speaker for testing purpose & it hasn’t created any crackling sound till now. So according to them, the A/V receiver seems to be fine but I have asked them to please continue to test for another 3 to 4 days & see if the issue occurs.
How can both JBL 625C Center channel & JBL 660P develop such faults at the same time, really can’t understand it. Could this newly added power hungry Sonetto II G2 4 Ohms speaker be the reason for it?
Anyway’z, I have informed the JBL representative about these issues & they will have it checked. I have requested them to kindly bring in their own A/V receiver, even a simpler one will do. This is just to check whether the Center channel again creates the sudden crackling sound when connected into their A/V receiver? Let’s wait & see.
In discussion, they also suggested me to consider: Arcam PA720 which is Class G amplification but what I fail to understand is that it mentions 140 watts per channel under the description but down their on next page, it mentions - 7 x 100W Class G amplification. It’s quite strange.
Overall, I am totally clueless with my purchase decision b’coz many audio dealer also asked why I bought a 4 Ohms speakers in a 6 Ohms environment b’coz rest all are 6 Ohms in my living room & I now feel I shouldn’t have purchased this Sonetto II G2. I feel adding an external Power Amp & whether upgrading or to stay with the present A/V receiver - RX-V685 should give me best output but again, the Power Amp which will now drive these power hungry Sonetto II G2 speakers, it’s sound will be such large (over power all other speakers in this living room) that all other speakers will get pressed under it.
It has all become so much of a confusion now & this Class A/B, Class D or now this new from Arcam - Class G - I feel as if I am back to school days where teacher teaches - A for Apple, B for Ball, C for Cat & so on…as if I am learning A,B,C,D,…
What’s all of these different Class, really clueless about it.
Overall, I am just so worried that these power hungry Sonetto II G2 doesn’t damage my other speakers or itself or this present or new A/V receiver that I look forward to buy.
My dream of setting up a very good Home Theatre experience has turned into nightmare & miserable.
I feel I was better off listening to sound from my TV, a very simple life with none of these complications involved. This is an ocean of troubles & needs wherein one has to keep spending more & more money but, the trouble never ends for sure.
Maybe due to such extreme complications & lack of exact & true knowledge about the Home Theatre systems, so many household across globe still consider enjoying sound from their regular TV instead of opting for a home theatre setup l, while it’s cost of setting up being another important factor to be considered & it’s maintenance thereafter…(-:
It’s all too very much of technical & not a normal buyer’s cup of tea for sure. Things are way too complicated in this home theatre world & no one has time to sit & learn it in this day to day hectic & busy stressful life. (-:
everettT
everettT
Hello Peng,
Just note that you typically only listen with a couple of watts the majority of the time, except reference levels and most don't listen that loud.
If you're using the system for parties in a large space, then you might worry about over driving the speakers
Hello Peng,
I understand this kind of concern is normal because there are many internet hearsay that are often rooted in misconceptions.
To understand it more, consider the following facts:
1) It does not matter how powerful the power amp is, your speakers will only draw what they need based on:
a) their sensitivity that is often given in XdB/2.83V/m, such as your JBL 630"s: 85dB @ 1M, 2.83V
b) your distance, because when distance is double, you lose 6 dB, likewise, you sit closer to say 0.5 of your original distance you gain 6 dB (that's equivalent to 4 times the power).
c) your listening habit, typically you will perceive about twice as loud if you have 6 to 10 times of the "power" applied to your speaker.
d) Before your speakers get damaged due to being "over powered", they will tell you loud and clear, as you will hear distortions long before that point is reached.
e) Despite fact d) above, it is true that speakers do get over powered frequently probably without audible distortions because there could be high peaks in some music that have very high dynamic peaks, but such short duration peaks won't cause damage, unless it is really high, that won't likely happen for real world use.
f) Even if you do get those rare extremely high, even damaging peaks, keep in mind that the less powerful Rotel amp won't make a difference because they can output very high power for short duration, and even if they cannot, it would mean the amp output voltage will clip, and that could also damage your speaker, especially the tweeters, such in different way.
Notes on points above:
on f), you must have read about the often debated topic on the internet, about whether speakers are more often damaged by under powered amps than over powered amps right? Both could be true, it just depends on a few other factors, topic for another day.
on b) is a rough estimate because you likely have room gain in the low to mid bass range, so you won't feel losing 6 dB, more likely 3 to 4 dB loss when you double the distance.
on c) again, just a rough estimate because our perceptions are not exactly the same, to some 6 dB would feel like twice as loud whereas some may need 10 dB (that's 10 times the power) to feel the same.
In case you are not familiar the dB, that is log scale, typically used in audio, take a look of the following table:
dB chart voltage power table conversion sound pressure sound intensity decibel voltage level levels ratio dbu dBA dBm absolute relative acoustic measurement volts watts and pascals database - sengpielaudio Sengpiel Berlin
It has been suggested already but you don't seem to understand, or believe?
In the links to some of the class D amps you can sort out those that are rated around 150 W, but you will be ill advised for reasons before, that is, use an online calculator to figure your actual "power need", before making a decision. Amps last for a long time so it is worth spending time on gathering up all the facts.
If you have trouble using one of those calculators, I don't mind doing it for you if you provide the following information:
- your seating distance.
- your desired SPL you listen to, keep in mind, 85 dB average 105 dB peak is likely what you would be listening to when watching a Star War movies, Jurassic park etc.
- Do you often listen to highly compressed music, such as many on youtube, rock concerts etc.
- Do you listen to classical music including large symphony orchestra's.
Same answer as above, need the facts based on you needs, so have to know your distance from the individual speakers.
Now, you can ignore all those requirements such as using an online calculator and go with the highest power amplifiers based on the speaker manufacturer's recommendations. For example:
For the Sonetto II G2 4 Ohms speaker, the specs say: 20-200 W, so a good recommendation would be to use amps rated for 400 W into 4 ohms, that would assure you can listen at the speaker's power handling limit during peaks, without causing damage. Peak power = 2X average power (that's just one of several facts to consider).
This is sort of a short cut, bypass the need of doing the calculations to determine your actual need. If you actually do the calculations, then you might find the 150 W Rotel is already powerful enough to get the best out of your Sonus Faber speakers, but if you ever change you habit such suddenly love to watch THX movies that have 105 dB peaks, and/or large orchestral music that has very high dynamic peaks, and/or moving to a larget room where you would sit further, examps: 15 feet from the speakers, then the 150 W Rotel won't be a good match. They would still be fine, but you won't get the best out of those very nice speakers.
Again, figure out your actual need first, general statements don't really help in getting the answer you need.
I dealt with that question already in my last post, may be you missed it?
If the fault is of intermittent nature, it will be hard to find.
As I said before it is a possibility, though I would say unlikely. It is not hard to find out, you can simply disconnect those Sonetto II G2 and do some experiments without the influence of them.
All good ideas, hopefully they will listen to you.
Why it is strange, to me that's typical, you get less when driving 7 channels simultaneously, vs 1 or 2 channels.
Many such dealers are not that knowledgeable, they have some basic knowledge but if you have done your own research and evidently you have, I would be willing to bet you are actually more knowledgeable than some of them. So, you are doing the right thing, instead of taking their words for it, you come here and ask questions.
Again, you came to the right forum, one of the best on the internet for those who are scientific minded, objective and want to learn.
So, try the following article and if you have specific questions about anything in it, do come back and ask for clarification:
What are the Different Types of Audio Amplifier Classes?
No one can help you much on this, unless and until you have done your home work, at the minimum use one of the easy to use (but not the best) calculators:
Peak SPL Calculator
Crown Audio - Professional Power Amplifiers | English
for the better, but more difficult to use ones, such as Benchmark's, iirc I've posted links to it/them before already.
You can achieve you goal, but you have to be willing to read and understand more, and stop worrying much about what the dealers told you, some of them more quite knowledgeable, but many are not.
I can understand the feeling, and I think that is why so many people would just pick an AVR, and use such a one box solution. In you case though, while you can do that, if you want to get the best of your near high end speakers, it is still a good idea to use a 3 channel power amp to assist whatever AVR you picked, unless you are willing to pay for the flagship models such as the expensive, Denon AVR-A10H, Onkyo RZ70, or the Cinema 30. Imo that would be for those who just want to get by, and in my opinion the value kings such as the AVR-X3800H/X4800H, or Marantz Cinema 50 plus a 500 W 4 ohms class D power amp will be better choices but now I am repeating what I and others suggested long time ago lol..
apoorvasheth
Since you are considering such an expensive (only relatively speaking obviously) AV receiver, I would suggest you spend some time to do the following:
- Research the specs and test bench measurements (hopefully there are some available) and ignore what the dealer tells you (I guess not totally, and it depends..)
- Bugs reports, reliability issues, warranty means little if you have experienced the inconveniences when something failed, especially if it is intermittent issues, even if your dealer is next door, they most likely have to ship it back to the manufacturers. Even reputable and highly reliable products such as Marantz's do fail as well, though may be better than average; and in more than a few cases, people had bad experiences with their major warranty services from their major service center, in some cases, had to send it out more than once and eventually end up with a replacement unit that was uses/refurbished etc..
- AV receivers are highly complicated audio devices, companies such as Audio Control may or may not have the same kind of depth, experience in this kind of products that the leading brands such as Yamaha, Denon and Marantz have.
All of the above probably don't matter to you if you are in the money no object category of audio enthusiast, otherwise you may feel the pain if you have to replace such an expensive unit in just a few years because of bugs, reliability, issues or just obsolescence due to new features that you may want.
On the extreme end (that's what I am being drawn to all the time now), one only need to spend less than $1,500 on something like a Denon AVR-X3800H, or a Cinema 40, or up all the way to the affordable AVR-X6800H that will match or exceed the specs of the AudioControl Concert XR-6 (example the DAC chip used).
The best AVR in terms of specs and measurements at the moment now appears to be the Cinema 30, or the Denon AVR-A10H that uses the brand new ES9017 that has about the same specs as the AudioControl's ES9026 Pro though it does has 124 dB DNR, that is 4 dB higher than the ES9017's 120 dB, distortions specs are the same, both have SINAD 110 dB. As ADTG noted, no one can hear the difference between 120 and 124 dB, or even 110 dB. Neither DACs are considered by ESS Sabre as their "reference" class.
To get the reference class ESS DAC chips you need to get the Denon AVR-A1H (may be the cheaper A10H but not sure), AudioControl Maestro X9, or go separate. For separates, the Anthem AVM90, or the Marantz AV10 are far superior in terms of value, both has the reference class ESS DAC ICs (mentioning it only because that seems to matter to you), the Anthem's has the same ES9038Pro that the Maestro X9 uses, but on Gene's bench, the AV10's actually measured a touch better in SINAD.
I only use some cheap, but good quality surge suppression devices at the outlets, in addition to a "whole house" surge suppression device at the main panel in the basement.
All those expensive UPS and so called stabilizer or regulators are silly (unless you are in areas where power quality/reliability is a real issue), but hey, they sell...
Thank you very much Peng for your response. Well, Denon AVR-A1H, Denon AVR-A10H, Anthem AVM90 & Marantz AV10 are way super expensive & far beyond my budget. While there is no issue of power where I live but even one sudden power failure & place my expensive audio gears in danger so, I am surely thinking of getting a UPS for safety of my audio equipments.
I have completely dropped my plan of getting AudioConcert A/V receiver as it is super expensive in which I can buy two audio gears. Taxes are quite high as well.
As for Cinema series A/V receivers, I had once been to their authorised service centre in my city & they said Cinema series A/V receivers are such well built that till now, not a single has came in for repairs.
apoorvasheth
Hello Peng,
Thanks for your response. The warranty period of any of the Marantz A/V receivers in India is just of 1 year. Getting a 2nd Sub in my living room is a bit difficult as no more space left to place it. And JBL 660P of 12 inches driver makes a very good sweet & punchy boom boom sound, enough to fill my living room, atleast at my sitting position.
So finally, I went ahead with option 2 & bought a pair of Sonus Faber Sonetto 2 G2 Bookshelf of 4 Ohms & a pair of Sonus Faber Aster (6 Ohms) to use it as an Atmos on Ceiling. But with these new additions, I’ve ran into a problem.
JBL 625C (Center Channel) created crackling sound.
So now, below is my complete setup:
T.V. - SONY A80L OLED (eArc on HDMI 3).
A/V receiver: Yamaha RX-V685 (Updated to latest firmware v2.14).
Apple TV 4K (128GB & TVOS 18.2).
Front Left + Right Speakers: Sonus Faber Sonetto II G2 Bookshelves.
Center Channel: JBL 625C (Studio 600 Series).
Surrounds Left + Right: JBL 630 Bookshelves (Studio 600 Series).
Sub-woofer: JBL 660P (12 inches driver).
And finally: For Dolby Atmos: Sonus Faber Aster.
HDMI Cables:
a) AudioQuest Pearl 48 4K-8K-10K Ultra High-Speed HDMI Cable w/ 48Gbps, UHD, HDR & eARC. (2 meters).
b) Ultra High-Speed HDMI™ Cable HDMI™ Connector | HDMI™ Connector | 8K@60Hz | 48 Gbps | 3.00 meters by Nedis (ProfiGold).
c) Bandridge 16 Gauge Oxygen Free Audio Pure Copper cable - used for Surrounds (JBL 630) & Sonus Faber Aster installed as Dolby Atmos (Overhead).
1) Sonetto II G2 - 4 Ohms (Recommended power amplifier- 30 W - 200 W).
2) JBL 625C - 6 Ohms (Recommended Amplifier Power Max 150W).
3) JBL 630 - 6 Ohms (Recommended Amplifier Power Max 150W).
4) Aster - 6 Ohms (Recommended power amplifier - 125 W).
5) JBL 660P (12" Powered sub-woofer system with 1000W amplifier). Power 500W RMS (1000W Dynamic).
I all of a sudden heard crackling sound from JBL 625C Center channel speaker & the sound being all of a sudden was quite frightening I have captured video of the crackling noise that JBL 625C created but this forum doesn’t allow to attach video files.
This has never happened before until these pair of Sonus Faber Sonetto II G2 power hungry (4 Ohms) speakers got added.
I strongly suspect the Center channel connector behind this Yamaha RX-V685 A/V receiver has blown off but I need to confirm it as well therefore, I have already deposited this A/V receiver at Yamaha Audio authorised service center & now waiting for them to investigate & prepare a report.
I am also going to register this issue with the JBL team to understand from them, the reason for JBL 625C & JBL 660P to throw such issues in such a short time of it’s purchase as I bought these JBL products in April this year.
In the meantime, this is what I am now planning;
or
or
or
d) JBL 625C itself.
Hello All & Peng,
Apologies for the delay in response. So, finally I picked up my Yamaha Audio RX-V685 A/V receiver from their authorised service centre on Tuesday, December 31st 2024 in the evening around 5pm IST.
The service centre technician did hear a crackling sound for a second when their simple speaker was connected into the Centre Channel connector. When he heard the crackling sound, the lights in their service centre too blinked for a second. So, they concluded that their is most probably an issue with the Centre Channel I.C. & therefore went ahead & replaced it. Again kept for testing for 2 days before I finally picked it up in 31st Dec '24.
From that day till now, I have NOT heard those fearful frightening crackling sound from the JBL 625C Centre Channel speaker even for a second. The "Good News" is that even the JBL 660P Subwoofer's white connector has begun to perform well. It can now detect & output low frequencies passed on from the A/V/ receiver. The sweet boom boom sound from JBL 660P btw -30 to -26 volume level is also super fine. Though a thing to note that there are other Bookshelf speakers in the room as well that do output Bass.
The Sonus Faber distributor suggested that I shall consider changing my JBL 625C Centre Channel speaker to Sonus Faber Sonetto I so that tonal quality matches with the Front Left + Right Sonetto II G2 Bookshelf speakers. At this moment, I have many upgrades to meet my expense with so can't afford to already working Centre channel be replaced with Sonetto I.
Now my conern is whether I shall consider buying:
a) A 2-channels Power Amp + Cinema 40 or 50 A/V receiver.
b) A 3-channels Power Amp + Cinema 40 or 50 A/V receiver.
c) A 5-channels Power Amp + Cinema 40 or 50 A/V receiver?
And, in my living room world of 4 & 6 Ohms mixture of speakers, what Ohms shall I set my Cinema 40 or 50 A/V receiver to (whenever I purchase) so as to make sure neither of these get damaged.
I had emailed to Marantz team & they are of an opionion that Cinema 40 or 50 to be set at a speaker's impedance level which is the lowest. In my case, it is Sonus Faber Sonetto II G2 4Ohms & 200 Watts so, I should consider setting Cinema 40 or 50 to 4 Ohms but that's very risk for the rest 6 Ohms speakers.
Gene always tells us to set the Impedance to 8 ohms regardless of the speakers impedance.
Might also consider the Denon X6800H, which is the equivalent of the Cinema-30 AVR. Power output is about 250W x 2Ch 4-ohms and 100W x 7Ch 8-ohms, which should be plenty of power for your speakers without any external amps.
