Audio out lcd/dlp projector
johnnyc327
Looking for a solid (inexpensive) audio solution for ceiling mounted projectors. Classroom and meeting room environments. What is the benefit of running the mini 3.5 in and out of the projector? No need for the 5.1 system. Just a couple speakers..
Any suggestions would be greatly appreciated..Thanks in advance
Johnny C
BMXTRIX
BMXTRIX
If the speaker inside the projeector is worthless, then you will need some sort of amplifier/volume control to get audio into the room. Realistically, a cheap A/V receiver can often do this at a far more cost effective level than a stand alone amplifier/volume control setup.
A 7.1 A/V receiver with speakers throughout the room running STEREO, not surround mode, so that all the speakers get equal volume works very well and can be had for a very reasonable price. It depends on the room, how many are listening, how permanent the setup is, etc., etc. It is the main reason why there are tons of commercial A/V installers in this world - they can do it for you easily and get it right - then give you a warranty on things.
