Yeah that is pretty funny. But I had no idea that any cable broadcast carried multichannel audio
. I live in the stone age. I should just go find my cave and forget about AVRs.
As for fluctuation, I do mean during program material. How exactly it varies, I'm not too sure of. More observation is necessary before I can tell you that. But I'm sure that I noticed very low volume on all HD channels and HD channels only. Also, on one particular HD channel, I clearly noticed that all music and background score was at proper volume, but dialog was inaudible. Maybe there was mostly dialog on the other HD channels as well and I'm basically not hearing dialog. Need to check on this.
In that case, the most likely situation is that I have not set the AVR properly to stereo format d'oh! That will be surprising as I'm fairly certain I should have done that but then as I never suspected multichannel audio, maybe I just didn't look carefully enough. I'll check when I get back home and report later.
