Audio differences between HD and broadcast
trnqk7
Read more closely-I said it doesn't matter what speaker wire you buy as long as it is of sufficient guage (so the resistance is low enough that you don't have losses). I could care less how much your speaker wire costs-$1 to $2 per foot isn't outrageous, it's really not too bad at all. I'm not suggesting you spend $.16/ft either. What I'm trying to get at is, unless you need to feel like you have the "best", "coolest", etc. wire, there's no good reason to buy something like Audioquest, Nordost, etc...or even Monster for that matter. It's all higher priced than what you can get from BJC, Monoprice, Parts Express, etc...even Rat Shack. What I think is dumb is some people paying $3k for a pair of 6ft speaker wires...I'm just trying to give the OP some reasonable cost suggestions. You mentioned that speaker wire was the weakest part of his system...that usually leads into esoteric wire discussions. Such expensive items often deter people from wanting to get into this hobby.
On a side note-if you have the money to blow and are happy with everything else in your system, by all means, by expensive, kick @$$ looking cables and revel in your superiority. It may not "sound" any better, but it'll look nicer than what I have, no doubt ;)
trnqk7
And I have read the suggested reading about wiring, several times. I'm also an electrical engineer. I don't know everything by any means, but I know enough to be fairly competent.
BobSD
You accentuate, if you want very attractive looking speaker wire =$$, I try to hide all my wire as much as possible so appearence is of NO importance to me, the sound is all that counts! I run it under the carpets or in the walls etc. It can really look unsightly when setting up a surround system.
trnqk7
Why do you act like I am attacking your choices? I could care less what you do-it was for the OP's benefit, not yours!
