I'm sure there is, but I'm guessing it won't be cheap.
The best solution would be a systems integration rig with something like a 12-20 channel amplifier and a control module. You can also get room to room controls so you have total control over the entire system from any room.
For this I recommend getting in touch with a professional whole home audio installer to get you a quote and go over options with you. At the very least it would give you an idea of what you would be getting into. Be careful though as some of these installers will try to omit important details about the equipment they're advising you to install. It's important that you know what exactly these items are so you can do your own homework and make sure you're getting a reasonable price.
