I really can not recommend that bass driver.  It really is just a mid range unit.  You can't get F3 below 75 Hz.  Also the driver has very limited throw, and handles little power below 120 Hz.  So that leaves no room for diffraction step compensation, so the driver will have a thin weedy sound.  So you would have to cross it over to a sub at 120 Hz at least which is far too high.
How did you get that driver, and can you return it?
This driver, will get you to 60 Hz at good power in a quarter cubic foot box or so. and down to 50 Hz in a half cubic foot enclosure. at good power.
I would only recommend your driver as a mid range unit and not a bass mid.
How big is your room and will speakers with single 5" drivers do the job?
Here are the possible bass alignments.
  Type: Standard one-way driver
  Company: Audax Industries
  Comment: Reference series
  No. of Drivers = 1
  Fs =  46 Hz
  Qms =  3.6
  Vas =  18.1 liters
  Cms =  1.78 mm/N
  Mms =  6.9 g
  Rms =  0.55 kg/s
  Xmax =  3 mm
  Xmech =  4.5 mm
  P-Dia =  103.8 mm
  Sd =  85 sq.cm
  P-Vd =  0.0254 liters
  Qes =  0.34
  Re =  6.2 ohms
  Le =  0.39 mH
  Z =  8 ohms
  BL =  5.97 Tm
  Pe =  50 watts
  Qts =  0.31
  no =  0.5 %
  1-W SPL =  90 dB
  2.83-V SPL =  90.24 dB
Box Properties
  Name:
  Type: Vented Box
  Shape: Prism, square (optimum)
  Vb =  0.217 cu.ft
  Fb =  54.59 Hz
  QL =  7
  F3 =  74.15 Hz
  Fill = minimal
  No. of Vents = 1
    Vent shape = round
    Vent ends = two flared
    Dv =  1.5 in
    Lv =  7.155 in
  Company: Seas Fabrikker A.S.
  Comment: H 1216
  No. of Drivers = 1
  Fs =  47 Hz
  Qms =  1.7
  Vas =  12 liters
  Cms =  1.4 mm/N
  Mms =  8.2 g
  Rms =  1.5 kg/s
  Xmax =  5 mm
  Xmech =  10 mm
  P-Dia =  99.46 mm
  Sd =  80 sq.cm
  P-Vd =  0.0388 liters
  Qes =  0.48
  Re =  5.5 ohms
  Le =  0.76 mH
  Z =  8 ohms
  BL =  5.4 Tm
  Pe =  60 watts
  Qts =  0.37
  no =  0.25 %
  1-W SPL =  87 dB
  2.83-V SPL =  87.76 dB
Box Properties
  Name:
  Type: Vented Box
  Vb =  0.259 cu.ft
  Fb =  47.9 Hz
  QL =  7
  F3 =  61.6 Hz
  Fill = minimal
  No. of Vents = 1
    Vent shape = round
    Dv =  1.5 in
    Lv =  7.839 in
  Comment: H 1216
  No. of Drivers = 1
  Fs =  47 Hz
  Qms =  1.7
  Vas =  12 liters
  Cms =  1.4 mm/N
  Mms =  8.2 g
  Rms =  1.5 kg/s
  Xmax =  5 mm
  Xmech =  10 mm
  P-Dia =  99.46 mm
  Sd =  80 sq.cm
  Qes =  0.48
  Re =  5.5 ohms
  Le =  0.76 mH
  Z =  8 ohms
  BL =  5.4 Tm
  Pe =  60 watts
  Qts =  0.37
  no =  0.25 %
  1-W SPL =  87 dB
Box Properties
  Name:
  Type: Vented Box
  Vb =  0.461 cu.ft
  Fb =  41.6 Hz
  QL =  7
  F3 =  50.56 Hz
  Fill = minimal
  No. of Vents = 1
    Vent shape = round
    Dv =  2 in
    Lv =  10.04 in
The SEAS driver is cheaper and has a smoother frequency response.
