Many portable devices may only produce around 1 VAC maximum output. With many headphones, this is simply not sufficient to power them when dynamic music is played. The same goes for headphone amps that work off a single 9VDC battery. Typically, <3VAC is available and there are headphones that need more than this for dynamic music. I have an AKG K340 that is very low voltage sensitivity. It needs >8 VAC for some of my most dynamic music recordings, or the amplifier will voltage clip.
-Chris
Actually, I was not considering battery powered devices in the equation. However for mains powered units considered here, a headphone amp with the headphone chip powered by a 12V/-12 supply, would have no difficulty producing 20 volts clean output, and that would produce over 1.3 watts of power into 300 ohm phones. The current would be 0.07amps, and therefore could be driven straight from the opamp, without a power amp.
I gather from their website Sennheiser consider about 300 ohms optimal for driving straight from the headphone sockets of CD players etc. I would tend to agree.
Obviously for a battery powered unit using a 6volt battery pack the impedance would need to be about 30 ohms, for the same power. The current draw 0.22 amps. Just about possible for some chips.
The 30 ohm phones could try to draw 0.66 amps from the +12/-12 volt supplied chip, which would be too much for an op amp. However that would be absurd for phones, as the power would be about 13 watts, if the amp could provide it. The amp would clip. However if the volume were turned down on the CD player so it delivered six volts, the spl would be just as high and clean. The power of just over a watt is fine for the majority of phones.
So Phones with an impedance in the 100 to 300 ohm range will do best with most mains powered units, as long as the supply voltage to the headphone amp is adequate. Unfortunately the consumer does not know the voltage capability of the headphone amp. However units in the 20 to 50 ohm range should work with either, as long as you understand you will have to set the volume at a lower setting if the headphone amp has a supply voltage over six volts. They will still play just as loud though.
I tried my Sennheiser 525 phones on a variety of units in my racks this afternoon. I think their impedance is around 160 ohms. They played clean and loud enough on everything, although the RME Fireface 800 and Revox A 700 drove them the loudest, to deafening levels in fact.
We seem to have opened up a confusing set of issues in this thread.
However the simple bottom line is this.
If the headphones you picked play loud enough, clean enough, and you hear no distracting hiss from your headphones, then you will not benefit by putting dollars into a standalone headphone amp. If any of these criteria are violated then you likely will.
It is just that there has to be some technical understanding to see why this is so.
