Nice pics! I didn't know the Ipod touch was wifi enabled.
I wonder if I'm the only one that that will recognize Sakura Diaries(bought that years ago).
How do you like the Ipod touch so far? I like the design and idea, but I'm not crazy about having to be stuck with the manufacturers software for syncing and converting files. I tried iTunes for awhile a long time ago and didn't like it at all.
Sweet. It's an ok show, but after watching it all, I don't think I'll buy it. Kare Kano (His and Her Circumstances) sounds a little better now.
I actually like the interface a lot now that I've gotten used to it. I will say the Nano and the Classic seem to have slightly more control over selection of playing music (at least I haven't figured everything out on it yet...) and that's my slight slight negative (if you want to call it that).
iTunes is a lot better than it has been. It's mp3 compatible and it will convert WMA files. Sync software is common for most mp3 players... it's kinda evil. At least iTunes tends to have a great selection, and if it doesn't suit your need (if you want cheaper songs) you can go to Wal-Mart or Amazon.
A case is required. You will scratch the back if you don't (but I got mine in a case as soon as the box was opened). The front is glass and is scratchproof pretty much.
I would recommend one, especially if the price came down. You might want to get a bigger one, but I have a crapload on it right now, and I'll be ok with selecting certain things to be on there
