You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser.
HTKamikazee
Audioholics Sheriff
Are you music fan? I've always been a 2-channel guy when it comes to critical music listening. It's not that I don't like multi-channel for music, but I prefer 2 channels for this specific task. The Intimus 2.1 Tower system from Aperion Audio.
This system features their award winning Intimus Tower and the Bravus 8D subwoofer with this in mind. I've gathered some useful information like features and specifications so you can have a better understanding of their characteristics. Who knows? Maybe this is the system you are looking for to start enjoying your music collection. Take a look at the following features and specs below and share your thoughts.
FEATURES (Intimus T Tower):
- Dual 5.25" Woven-Fiberglass woofers deliver excellent bass and lush mid-range sound1" custom designed silk-dome tweeter for smooth, clearly defined highs at even the highest volume levels.
- Hand-polished Gloss Black Lacquer finish.
- Curved design aesthetic and small form-factor to blend seamlessly with your decor.
- Anti-resonant cabinet.
- Ten year warranty.
- FREE lifetime technical support
SPECIFICATIONS:
- Frequency Response (+/- 3dB): 55Hz - 20kHz -- (+/- 6dB) 45Hz - 22kHz
- Impedance: 6 Ohms
- Sensitivity: 89 dB
- Recommended Power: 50-200 Watts.
- Tweeter: 1" Audiophile-grade Silk-Dome Tweeter.
- Midrange: (2) 5.25" Woven Fiberglass Composite.
- Driver Configuration: 2-Way
- Enclosure: Type18mm MDF, Ported.
- Dimensions: 38" H x 6.3" W x 8" D (Base 9.25"x10.75")
- Product Family: Intimus
- Placement Location: Front speakers
- Weight: 28.5 lbs
FEATURES (Bravus II 8D Subwoofer):
- Single down-firing active 8" aluminum driver.
- Dual side-firing 8" aluminum passive radiators.
- 300 watt class D amplifier.
- USB power jack for easy wireless connection.
- Small internally braced 3/4" HDF sealed enclosure.
- Virtually vibration-free cabinet.
- Ten Year Warranty (two years on the amplifier)
SPECIFICATIONS:
- Frequency Response: -3dB, 33Hz - 200Hz -- -6dB, 30Hz - 180Hz
- Amplifier Power: 300W RMS
- Woofer: 8", high-excursion aluminum driver with dual 8” passive radiators.
- Driver Configuration: Single Driver with Dual Passive Radiators.
- Enclosure Type: Sealed and Internally Braced, 3/4" HDF.
- Dimensions: 13.5" H x 12" W x 12" D (with feet attached)
- Product Family: Bravus
- Placement Location: Subwoofer
- Weight: 27.0 lbs
- Finish: Gloss Black
SYSTEM PRICE: $1,197.00
