I'm going to be spliting up my two cabinets to make four in the next two weeks
After some experimenting with my new OM system from PE and a couple extra subs i can easily see the improvements multi sub placement around the room can do.
I'll be using a MiniDSP to configure all four subs at their new positions. The Mini will have to do a LT for each sub, delay, XO, and gain....
This all started after reading the Harmon white paper Welti and Devantier did......Thoughts ?
Here's a pic of the Dayton 12"/ Dayton 240 i built to do the initial experiment with. I now feel the 12" driver is a compromise due to size.
Here's a graph showing how the Aux sub filled in the hole, but the response was not across the whole listening position and i would rather use my 15" Tumults around the room instead of the 12's..... When the sweeps approached 105db the 12's showed some signs of audible distress
