I agree with t3031999 and Sheep.
Most of your speakers are at 88/89 dB/w/m and at 6ohms.
The receiver will have to work harder to supply the necessary power needed.
Since it has to work harder...if it's not properly ventilated, it'll have problems.
As I mentioned in another thread - 5990 is rated at 120x7 @ 8Ohms, .04THD. straight from the receiver's manual.-j_garcia
If this is the case, then yamaha's website is wrong. And you really need something more to push those speakers.
After setting your speakers to small, and if it still isnt loud enough, you will probably need a few amps to properly push those speakers.
NS 777's RMS are at 100 Watts, Sensitivity: 89 db
NS 555's RMS are at 150 Watts, 300 Watts, Sensitivity: 88 db.
I used to have to push my speakers hard..then i got a amp and a jblpro speaker for my center.
Reorx
