Any Good/Cheap Tri-pods?
speakerman39
speakerman39
Folks, I have been using the same tri-pod for a good while now. It is merely a cheap one at that. However, it seems like every time I turn around small screws keep coming out. Unfortunately, they are also hard to put back in. Especially, with my poor eyesight. That being said, can anyone recommend a good, but inexpensive tri-pod? I don't mind to pay a little more than I did for the one I have. Seems like I gave like maybe $20--$25 for it. Just need a good basic tri-pod. Thanks!
Cheers,
Phil
slipperybidness
slipperybidness
Cheers,
Phil
Use a little LockTite to keep those screws from coming back out.;)
I think you want a "boom mic stand" or a "boom mic tripod", right? I really can't help much to tell you which one of those to get, but I do love me some parts-express:
https://www.parts-express.com/Search.aspx?keyword=tripod&sitesearch=true
As far as a "camera tripod", this one is quite good for my needs:
https://www.amazon.com/gp/product/B00NOEH4FS/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
speakerman39
speakerman39
Yeah, more like the camera tri-pod. The boom mic stands look weird.....LOL!!!! I need a stand for my mic when running Audyssey. Plus, when I use the UMiK 1. Maybe a camera tri-pod such as the one that you linked for my Denon mic and a boom mic stand for the UMiK 1? I can tell that the camera tri-pod that you linked is much better than what I have. But, it is also much more expensive too. I think having (2) stands will be helpful, no?
Cheers,
Phil
slipperybidness
slipperybidness
Cheers,
Phil
I'm not the best to help you out on what you need for measurements. The last time that I ran MCACC on my Pio, I used a little Gorrilla tripod to attach the mic, then shoved it between my couch cushions to get the mic right at the ear position of the MLP.
I really think a boom mic stand may be better for that application.
I can tell you that the Dolica camera tripod that I listed is quite a nice tripod. It folds up nice and small, and honestly for the quality the price is good.
I'm using it as a tripod for a 90mm telescope! Rock solid mounts are a requirement for telescopes. To connect my telescope, I have custom designed and 3D printed the mount parts that I needed to attach to the Dolica. I need to post some pics of that work.
I prefer using my mic boom stand for positioning near/around furniture over my tripod....use it for both Audyssey and measuring mic (Omnimic2)
speakerman39
speakerman39
Yeah, I will get a new tri-pod AND a mic boom stand as well. That should take care of my needs. Just going to get a better tri-pod this go around. Have owned enough of the very cheap ones. It is time for something more reliable!
Cheers,
Phil
