Anthem mrx740 is motherboard compatible with mrx 700
K
kvkellylee
Can I use a mrx700 as a replacement option for a mrx740
As I can’t afford a new one from agents and can’t find a 740 used mrx Anthem
Any suggestions
everettT
everettT
Any suggestions
I'm not sure what your asking as the title is confusing.
dolynick
You'd have to ask Anthem to be sure, but I can't see this possibly working.
Any suggestions
Receivers are not computers. I don't know what you mean by motherboard. I suspect you mean the processing board. You can't go swapping boards from different receiver models. Even when you change a motherboard in a computer, more often than not there are other changes that have to be made.
K
kvkellylee
Ok thank you just wanted check will a mrx 700 main board electronics board work on a mrx740
