Here are the room correction settings after running Audyssey with the Onkyo 608.
Front L/R/C set to 40hz, Surrounds set to 50hz.
Distance; L/R at 15'.0. Center was set to 14.'0. And surrounds were set to 6'.0
Before running Audyssey, I turned the sub level down to about the 10pm position. The sub was set at 26'.0
I ran YPAO and the settings are different.
It set
all speakers to large. Distance; L/R 13ft, Center; 13,5ft. Surrounds Left 6.8 ft. Right 5.8ft. Sub, 13.5 ft
Levels; Front L/R 0.0dB, Center +2.0dB, Surrounds L 0.5dB, R 0.0 dB. Sub +2.5dB
Sub xover was 60hz.
I set the surrounds to small and xover at 40hz but left everything else the same. i also chnaged the sub distance to 26ft. I probably should have left things as YPAO set them, but I know more than some room correction software...
