At the moment (at least untill i upgrade to a receiver), I am using the Aiwa NSX-D22, with it's SX-ND22 speakers (and the - unhooked, crappy - surround speakers) that came with it.
I have this set up (arrows represent path of connection) :
VCR --> AUX IN (on NSX-D22) --> COMPUTER TO VCR (Via "Y"-Cable) --> TV TO VCR ALSO.
Basically, I have everything routed to my system, through the VCR.
Today, I was watching TV and the right speaker cut out, I figured it was a wire problem so I checked. Yes, the wire did seem to be "fraying" (for lack of a better term), so I stripped it, which took a while because copper kept coming off in the process and making the wire width to small, but I got it in. Still didnt work. I checked all composite video and audio cables, all good. I thought, "oh well, I'll eventually get a new receiver in a while anyways, for now i'll just nuse headphones." I put some headphones in, worked great! Took them out, "wow, that speaker works now!". It cut out a few times more and i just kept plugging in a wire into the headphone jack to fix it. It seems to be working now, but why would the headphone jack cause that if the left speaker was still working?
Also, another reason I dont like these speakers is the bass, it isnt deep enough, sounds really bad.
Thanks,
Trav
