Since Dr. Floyd E. Toole seems to be the last word on sound reproduction, I thought I would get his book to help me with my new room/speaker setup. The first thing that I found out, for a number of reasons, Dr. Toole is not a fan of "Computerized Room Correction" he believes it has no value and doesn't solve the problem of speaker/room relationship. "Just another Corporate Gimmick"
So I'm on the path of bliss with Dr. Toole when I run into my first problem. Getting the anechoic data set for the speakers I purchase. Since they don't come with the speakers, not much information, I decided to write the company.
First Email: "I just bought some Focal speakers, and I'm trying to get the anechoic data set for loudspeaker for the Focal Aria 936 CC900, 906. I need the data, so I can set the speakers up properly. Thank you, and I await your response."
Focal Response: "Unfortunately, we do not have such data available for sharing, Please let me know if I can help with anything else."
Second email: "Without that data, how can the speakers/room be setup?"
Focal Response: "Your Room is not an anechoic chamber, therefore the data is useless, the readings are done during Transducer Design in order to make sure they attain the design spec. When placing in your room, it comes down to personal taste, and if you need that level of detail, the need for a professional reading is recommended for each different location you may place them, because once the readings are done, and the room is treated, you can never move the speakers unless you re-read the room at the new location, and re-treat (diffusers, sound traps, etc.).
Third Email: "According to Dr. Floyd E, Toole's Sound Reproduction 3rd Edition, I will need the anechoic data set for these loudspeakers. The test data you provide is nonexistent, other than specs, with the speaker. In order for me to set up the speaker/room, speaker naturality, will be needed. Thank you and I await your response.
I' waiting for a response. Do I really require the data; haven't gotten that far into the book.
