Android to reciever via Bluetooth or RCA?
W
Wildings
Analog output from a PC running the Tidal App is one way, other than that the Audioquest Dragonfly USB DAC is the cheapest way to get it without using their app, as far as I know.
I have 3 Bluesound devices at home that do it for me.
Thank you. I thought it was being done on my PC with the Tidal app....I do notice the small display box changes from Hi-Fi to Master on related selections.....so does that mean it is going downstream to my headphones, or just that I have selected a Tidal master file?
K
KenM10759
Yes, your headphones are getting it. If you have another analog output (usually a 3.5mm socket on the sound board), you would be able to get a cable like I have to send it to the analog inputs of an amplifier.
W
Wildings
Thank you. I thought so. I'd sit connect DAC to home theater that way at one time...but are no longer in same room. It is only on infrequent occasions that I use home theater for music listening....so was reflecting on ways to use my phone as a source.
