txhorns said:
Do I need to get a digital audio cable or can I just settle for the analog RCA type if I want to use it for both DVD and CD purposes? I don't have any digital CDs yet but I may get some in the future.
Since you are contemplating using DVDs and CDs, these are digital formats.
The player will pass both a digital signal and or an analog signal to a receiver for processing of any kind.
If you want to pass digital signals from these players, you should use a 75 ohm, as mentioned by mark. These cables come with various names: digital, video, component video, composite video, etc. They are all the same cable but the makers get away with charging more for a fancy name.
With a digital audio you can get multi channel DD, DTS or just 2 ch.
If you only want 2 ch analog, your cable choices increase. You can use the above mentioned cables, plus what is called audio interconnects. These usually have a red and white RCA type plugs and usually costs less. You would use any of these as well for multi channel audio from DVD-A and SACD as they only pass analog out for now.
Now the fun begins and don't mean to confuse. Experiments have shown that in home audio applications, short cable distances, digital audio can be passed flawlessly by coat hangers
so if you wish, you can even try those analog interconnects with the red and white plugs.
