That really depends what your needs are. Generally, if your system does not suffer from hum and the power source is "conditioned" well
, there may not be any significance. If you plan to add several amps to the system at a later date and more cabling, they could induce hum, so you may want to detmine if that could be a problem in the future.
Read the
review of the balanced/unbalanced listening test.
Finally don't be swayed by the literature...listen to the system yourself, does it makes a diffence, is it value for money and or, will the power amps be able to accept balanced inputs. (if you use the Parasound 5250...it doesn't)
Cheers...
Dapper Dan...
