Amplifier technology from 2001 to today? What has changed?
Landmonster
Landmonster
Hi guys.
So aside from a sub woofer, the next main purchase I will be looking at is a home theater amplifier. I'd like one to power all the speakers, but if that is too costly, then at least the front channels. I haven't looked at home theater amps since around 2001, when I owned my last one...and I'm wondering if the landscape here has changed!
I am planning on using new Polk LSiM 707 speakers, and according to the manufacturer, they sound their best with 250+ watts per channel at 8ohms. As I am sure you know.... amplifiers capable of this kind of clean power, especially in multi channel, are quite expensive!
I need some guidance in picking the best amp, and narrow down my choices I'd like a 2, 3, or 5 channel amp... capable of at least 250 watts on the main speakers (or close to it). Or a combination of the 2, such as a powerful 2-3 channel amp, and a less powerful 5 channel amp. Monoblocks are fine too!
  1. My question is, has amp technology changed much in the last 15 years or so? If so, in what ways?
  2. Is it wise to be looking at gently used 10+ year old amps? If not, why not?
  3. If old amps are fine.... what would be some good brands or models to search for?
  4. If I should be looking at new amps... what are some good recommendations that would meet my needs here? There are alot of new budget brands that have popped up..... Emotiva, Monoprice, Outlaw, etc.
For example:
I came across a used Sunfire Cinema Grand Signature (425 watts x 5) locally, for $1200. This appears to offer alot more performance than what I could buy new today for $1,200... but I am sure there may be some details or other factors here that I am overlooking!
Was this amp ever any good? How would it compare to a modern 5ch amp from today's standards?
Details: https://hometheaterhifi.com/volume_6_3/sunfire-cinema-grand-signature.html
Thanks
Speedskater
Speedskater
Well Class 'D' amps have improved, at least for any given price point.
But on the other hand, some really good chips and transistors from back then are no longer available.
Kvn_Walker
Kvn_Walker
You most likely won't be able to stay in the room with those speakers with 250 watts actually going into them.
What's important is having headroom for musical peaks while listening at levels you enjoy. While there's no such thing as too much power in reserve, you won't tap into it very often unless you listen really really loud.
All that said, I (and many others here) can personally recommend the awesome Outlaw 2200 monoblocks. Highly doubtful you will be left wanting.
Landmonster
Landmonster
I saw those. 200 watts per channel? I don't recall them publishing specs on them.
On that note, what specs are most important for an amp?
slipperybidness
slipperybidness
Most important specs for an amp section:
Continuous power at full bandwidth--but unfortunately not many amp manufacturers will publish this number. So, you have to do what you can with the power specs that they do publish.
THD + N spec
Other important specs are--ruler flat frequency response and low output impedance. but, modern SS amps, these items are a given unless the FR was intentionally shaped by the designer.
S/N is somewhat important for an amp, but it is really critical for the pre-amp stage.
Landmonster
Landmonster
What about the monolith amp offerings? They seem decent for modern multichannel amps
I am open to a used amp as well, ideally 200+ watts per channel for 5 channels driven with topend sound quality
slipperybidness
slipperybidness
I haven't seen a complaint about the Monolith, seems solid.
Personally, I would probably take Outlaw over Monolith.
https://www.outlawaudio.com/mofcart/electronics.html
I would think the model 5000 @ 120WPC would be plenty, but I'm not familiar with those Polks.
Why do you want 200WPC?
Landmonster
Landmonster
Look up the Polk lsiM 707s.
They apparently have excellent sound reproduction, but they are notoriously power hungry
The Polk reps say they sound the best with tons of power, 250-300 wpc. Something like the emotiva xpa2 or higher.
Many users confirm this... That they are less than amazed at these flagship speakers driven by an AVR... But transform when given power from a real amp.
slipperybidness
slipperybidness
Max output for 120W vs 200W is <3dB..........
Of course, there is headroom to consider, not just max output
Phase 2
Phase 2
Hi guys.
For example:
Thanks
1200 for that amp is a fair price, but how old is it? Let's just say 18 years old. You can get a new 5 channel for 2 to 3 bills more.
Landmonster
Landmonster
Yea it's from 2001 or 2002. It has 425 watts per channel.... But the finish is kind of dinged up.
I just wondered if amps has improved or changed much along the way
slipperybidness
slipperybidness
The only real improvement/change is the proliferation of good Class D circuit topology.
Beyond that, amplification has been a mature technology for quite a long time.
I have a ~1997 vintage Parasound still going strong. The only reason I would consider replacing it would be for something smaller and more efficient, or if it fails.
Hetfield
Parasound rocks, I am powering my HT with a 5 channel Parasound amp.
Sent from my Pixel using Tapatalk
slipperybidness
slipperybidness
Agreed, for the most part.
I use a Para 1206 and a zCD, both are good pieces of kit.
What I call Polk mythology. The speaker has no idea you've got 300wpc unless they're (i.e. all 300 wpc) in use.
Phase 2
Phase 2
I'm No amp expert here, but Bob Carver's amps have his umm unique signature? So to speak, PENG, I believe can speak volumes on amps, he or M Code can go into more detail on specifics of amp designs. Bob Carver had a way of taking a SS amp and making it have a signature sound the guy is a guru for sure with amps. I believe that's what made him famous so to speak. He could make a SS amp have a "tube" amp like sound. Maybe do some research on ole Bob Carver, I did and I found the guy to be a very interesting fellow with what he brought to audio with his designs.
