Of course, here's an example:
http://www.outlawaudio.com/products/2200.html
The specifications for the gain/sensitivity are stated as below:
Gain: +27dB for full output
(1.7V XLR input sensitivity)
(850mV RCA input sensitivity)
Two mistakes for sure. 1)The gain is actually higher, more like 28 dB. 2)The RCA input sensitivity is much lower, more like 1.6 V, not 850 mV. I don't know what it is for XLR as I have not tried it yet.
Now, let's pretend you are shopping for an amplifier, and figure that you need a power amp that has relative high sensitivity of say 1 V, using RCA inputs because you plan on using an AVR that has relatively low pre-out voltage, such as the Yamaha RX-A860 that Gene tested last year.
So when you see Outlaw's published spec, you may simply assume the "850 mV RCA input sensitivity" is more than enough, when in fact with 850 mV you will get less than 60 W from the M2200, and with 1.2 V the output will be about 114 W. To get the specified rated output of 200 W into 8 ohms, you need about 1.6 V.
They are not the only one who don't seem to pay enough attention to the accuracy of published specs, Denon, Marantz, Parasound, and someone just reported the Monolith too (regarding the transformer VA specs) also have inaccurate or at least confusing or contradicting data on their website as well. If you want another example, take a look of the THD figures Denon provided on their website, for the X4400H (in the comparison table, it stated 0.08% 105 W in one place and 0.05% 125 W in another. We both know the correct figure is 0.05% as that seems to be their standard for the 4000 series and above models, obviously not everyone knows that, or cares about those things. That's why I stated " I don't think that is an issue at all for the vast majority of potential buyers".
