mike c said:
couldn't they have conveniently TYPO-ed the impedance so as NOT to scare away potential buyers with the low ohm rating?
or isn't there a possibility that this set of speaker dips 4 ohms more often than others ... considering the number of drivers ...
but anyway, even polk themselves recommend:
500w recommendation is ginormous.
If, this is the same issue that I remember, I called them, or emailed them to be sure. The nominal impedance is 8 ohms. If it dips below 4 ohms enough then the nominal would not be 8 ohms. The algorithm for the calculation changes and affects the nominal rating. Since the nominal is 8 ohms, I cannot accept the below 4 ohm being more than other 8 ohm speakers, not yet with no evidence anyhow.
Number of drivers don't matter. What matters is nominal impedance, sensitivity. As you can see, they recommend 50 watts and more.
Just because you have a 500 watt amp doesn't mean that your 80dB spl music will sound different, just that is you really crank it up, any really high dynamic passage will not be clipped. And, dynamic passages of that magnitude are few and far between.
But, again, this revolves around what I remember the previous discussion may also have been about this speaker. If not, then it is a different issue.
