The room is 19 x 13 with an 8 ft ceiling.
That is a bit less than 2000 cu ft.
The results of the cals are with the volume control at zero, which is rated amp power.
In comparisons, my room is 3130~6300 cu ft, depending if the sliding doors to the DR/Kit are closed or open. With speakers of 91db sensitivity.
In my room, not counting subs, I could reach 114db for 5 channels. (220 wpc)
But I also have two back channels driven by the receiver @ 90 w plus 4 subs having a total of 2900w.
But do I play at full volume, no, most of the time it is set @ -20db, depending on source. So there is plenty of reserve for sound effects during movies.
But, concerts on HDNet, their volume is so low that I usually have the volume set @ around only – 6db.
