Firstly, I would not use a 120watt amp on tweeters; easy to over drive them and smoke them.
The only way I see it that you could deliver two 120 watts to the same front speaker is if you could send that speaker's signal from the pre amp out, split the signal and send it to two amp channel's inputs. But my vision is not always 20/20
