Amp for NHT 2.5i - suggestions?
1
105sixteen
If you have the jumper straps then use them - best IMHO (NHT 2.5i manual page 4 figure 3)...
My speakers came with cables (banana plugs) 4 wires of 10 AWG for satelites and XLR for subs.
Interesting, I do indeed have the jumper straps but from what I've heard from other owners of the 2.5is, bi-wiring is the way to go with these (or bi-amping if possible - which I will not be doing yet). I will probably try hooking them up with the jumper straps also to see how its sounds, but I feel like I will probably end up bi-wiring them.
Boerd
The speakers have an internal crossover - I don't see the benefit of biwiring - the drivers are connected through the crossover regardless.
TO prove you that connect only a the bottom RCA (no jumper) and all the drivers will sing (the tweeter will get less power but still). I don't buy this biamping at all.
You're better off with one powerfull amplifier and using the jumper.
Let's say you play classical and organ comes in... IF you use 2 amps 150W each the one driving the lower freq drivers may run out of juice (conceivable). The amp powering the tweeter is limited in helping the bass due to the crossover slope.
If you use 1 amp 250W and the mid/tweeter during the organ pasage don't suck much energy the rest is used by low freq drivers (power "shifts" on demand instead of arbitrarily being limited 50%-50%)...
My 2c.
Thirsty93
Thirsty93
I use a Yamaha RX-V2400
B&K Reference 125.2 for mine with a Synergistic alpha Interconnect Kimber cable 8 TC Speaker cable they sound awesome!!!
ParadigmDawg
ParadigmDawg
Boerd is correct, Biwiring does nothing. I use Biwire just because it looks cool and I am all about looking cool.:D
rioverdej
Hi I have a pair of NHT 3.3s. They like alot of Power, but they are 6 ohm speakers. I drive these with a Bryston a 9b sst 120w x 5 and I drive the built in subs with an old Macintosh Mc 2205 ( 200 watts per channel ) the system sounds great. I love NHT speakers. I also own NHT audio center 2. BTW though the Bryston Amps are expensive, they carry a 20 year warrentee from the date of Manufacture and the warrentee is transferable.
chris357
chris357
i agree on the biwire thing.. i do it because i bought the cables but I didnt hear any difference.. however going to my 250wx8ohm 500wx 4ohm amp made a HUGE difference..
POWER = happy NHT 2.5s
I actually have refular cables to and have thought about switching back.. but my amp is to heavy to move to get to the back :)
