Adam
Hi, all. I was wondering if anyone else noticed in the past ~week-ish that Amazon Instant Video only contains PCM audio. My Sony blu-ray player (BDP-S3100) got a software update, and now I only get PCM from AIV. I don't know if they are related, but the happened at about the same time. I was watching the same shows last week, and they displayed as "Dolby Digital" on my receiver. I ask because on the blu-ray player, the PCM audio is only in stereo (and for the life of me, I can't find any way to change that) versus 5.1 like it used to be.
I turned on my Sony PS3 to check if it was just the blu-ray player, but it also got an update (I don't know how recent, and I haven't used the PS3 in a while), and AIV is only PCM on it, too. It is multi-channel on the PS3, so Amazon didn't just downgrade the audio on all those shows unless the PS3 is converting stereo to surround, but I bought the blu-ray player for streaming because the PS3 fan is loud.
Netflix still sends bitstream audio, so it's not a universal issue with the Sony update.
Just curious if anyone else had this issue, and if you figured out a way to fix it. Thanks.
