alpine type R 12" car sub, any good for home theater?
the caveman
hey guys am thinking about using an alpine type R 12" as the sub woofer in my home theater set up and i was wondering if it would be a good choice
thanks jesse
GranteedEV
GranteedEV
This?
http://www.alpine-usa.com/product/view/swr-1223d/
How much are you paying for it?
It models decently, in a 2-3 cu ft box tuned around 22-23hz. However it's not the most sensitive driver in the world... expect to need much amplification to drive it decently in any huge room. I don't really like the punchyness i'm seeing in the transfer function but i guess some people do. It isn't a bad driver, with a decently low fs and ~12.6 BL but I do think a shiva or LMS-R would likely best it.
the caveman
the sub is a duel 2ohm and i have a matching amp left over from an instal i did in a mates car thats the only reason i was going to use it.
but you say it could work well?
and if i do you it would you recomend ported, seald or a bandpass box
annunaki
annunaki
Moderator
This driver tends to work best in vented applications when using in the home environment. I cannot provide specifics right now as I am using my iPhone and not my pc with my modeling programs.
The driver itself is actually quite well designed from a linearity perspective.
GranteedEV
GranteedEV
I recommend a ported box, with the VC wired in series. Maybe a tapped horn to increase sensitivity, but tuning it and folding it would take some time.
the caveman
So vented 2-3 cu ft tuned to around 22-23 Hz
Will start designing a box.
thanks jesse
It might work but it's not made for use in a room. There's a big difference in how the woofer will couple to the room vs the interior of a car, regardless of how it sounds outside of a car. A sealed box in a car with the windows down is effectively a bandpass box, although its tuning hasn't been calculated.
the caveman
good point, but i guess its going to be good enough to get me started on my build.
How big is the room where you'll use the sub? If it's smallish, like 10'W x 12'L x 8'H, it should be OK. Make sure the Q isn't too high.
