Affordable Subwoofer cable
Nomo
Nomo
Any digital coax cable will work just fine. It doesn't need to say "subwoofer".
Try bluejeans cable or even Walmart or RadioShack.
markw
Ain't no real magic to a "subwoofer" cable.
It's just an audio interconnect. Virtually any well constructed interconnect will work fine, even RG/59U with "F" to RCA connectors on the ends.
MIKED33 said:
Can you point me to a decent/affordable 20'+ subwoofer cable?
I wanted this but it's on backorder:]
Get some RG 6 or RG 59 cable TV cable from Radio Shack. They should have a 25ft cable easy for not much $.
G
GreenJelly
dont spend allot of money, and dont worry much, start with something cheap. I had a wire running around 25 feet, into a cheap subwoofer, and I could hear the radio coming from them; however that was my only bad experiance with RCA wires.
My fear of RCA wires are based on the fact that any noise they pick up will be amplified. I dont buy into the speaker wire BS, but I would spend a little more money on some nice shielded cables. I spend around $20-$50 on a subwoofer cable, since its usually a long cable... The rest of my RCA's are the high quality RadioShack brand:)
However, if your subwoofer doesnt cost allot of money, then dont worry about it, buy a set of wires.
Also, your talking about under $10, and you just cost me about 15 minutes to respond... I will be sending you my normal consulting fee based on $150/hour.
