hi guys
this is my first post to you all
after reading and digging alot finally i have zeroed down on onkyo reciever tx-sr 875, want to know the matching speakers. i love to listen music and my dad likes movies. want something which will serve both
I'd go along with what most of the others have told you. Hold your own auditions with your own source material [several good music CDs plus several DVD movies with good audio] and see what you like. When you find a set of speakers that you love in-store try to get a home trial [with full return rights]. If you can swing this then you're in great shape.
If you're looking for advice like which XYZ brand should I buy though I think we'd need more info like budget; are you looking at bookshelf speakers or towers; do you want a subwoofer; are you looking at a 2.0 system, 5.1, or 7.1 system, what's your room size, etc....
Note: I wouldn't take other's recommendations on blind faith. Please audition speakers yourself if possible.
