I went to a small store and got a price offer lower than I expected for both the RX497 and the B&W 686 and 685 (about 30% lower than I previously had seen during extensive research on the internet), both speakers I'd previously considered out of range. However, this is mainly a repair shop, no listening room although they do sell equipment. The 7355 was more expensive than the cheapest I'd seen so far, but seemed at the regular price.
I then went to another store (part of a chain) where I knew they do have a listening room. There they don't have Onkyo, nor B&W, and they did not have the RX497 in store. So, I listened to some speakers, albeit with a slightly more expensive receiver (RX797), and a different cd player (yamaha cd-s300).
After asking how I like my sound and what genres, the salesman let me listen to some speakers, he thought about Wharfedale and Polk. We started with the disc I'd brought with sonatas for lute vol 8, part of the excellent naxos series of sonatas by Weiss played by Robert Barto.
First up were the Wharfedales, and they were terrible. Booming bass on a solo soft instrumental recording. Next were Canton which he added in to the mix after noticing how much I disliked the Wharfies. These were good, as were the Polks that came after.
Then some doom metal, Skepticism's March And The Stream. To my surprise, the Wharfedales did sound fine here, where I expected another round of booming bass. The Cantons did possibly edge out the Polks here, but both sounded good.
Next again classical, Bizet's Carmen suite. Here he added also some Boses into the mix, which were quite terrible with booming mids. The Cantons did edge out the Polks ahead of the Wharfedales, but all three sounded good, much clearer than I'd heard this recording before.
Now came pricing with the Cantons turning out to be the GLE430, more expensive than the 685s though about 10% cheaper than on the internet, and the pricing for the receiver higher than in the other store. The cd player also more expensive than the Onkyo in the other store.
Noticing that abroad the 685s are about 50% more expensive than the 430s, should I just go for them, especially since I can take them back to the store if I don't like them? And also get the option when I buy a system from the small shop to get two pairs of speakers home (B&W and Polk) to compare them at home.
Now, I'm still wondering what model the Wharfedales, Polks, and Boses were. I was tired and forgot to ask. The salesman said the Wharfedales were Evos, but they had two front bass reflex ports, and I couldn't find any Evos with those so maybe he made a mistake and it were Diamond 9s. The Boses can have been 201s or 301s, they look quite similar. The Polks didn't have any special look so I don't have a clue at all. Any ideas? Just curious.
Also, for how long do I buy the system? I'm thinking I should count on ten years.
