Advice please
  • Thread starter Thread starter mark_putnam
mark_putnam
1
0
0
Ok so i recently blew up my 5.1 reciever, it was a Denon which was pushing an all infinity 5.1 setup, primus line, 360 towers, 10 inch sub, primus 150 bookshelfs were my surround speakers, it sounded decent and had enough power for me i guess..
I got on Ebay a Pioneer elite 01THX reciever for a decent price to replace this, soon after i decided i need to make use of this 7.1 capability soo i went shopping, I picked up some Mirage speakers which sounded great in the store, i love these speakers but... my real problem im having lies in:
This receiver sounds great when i play ps3 or watch movies, but it doesn't push music as hard as i want it to, i've been thinking of picking up an amp to push it harder 90w/ch pre amp sounds really weak considering i know these speakers are nowhere near their limits on maxed volume, i'm also thinking of a bigger sub the towers do seem to dwarf the 10 incher, and i know its not because it's 10 inches, it just isnt being pushed hard enough.
yes i have tried all kinds of different settings on the reciever and it just isn't being pushed the same way no matter what i do with reciever settings, i set it higher DB and it sounds wrong, i have tried every setting and i cant get the same deep push from this sub as i could before without dwarfing out my mids and highs.
Really my question is this, given my current setup, what could anyone reccomend to make the speakers push harder? It sounds great on mid volumes and even at max volumes, but i know that it's nowhere near it's limits and i like my music a lot louder than my movies
I was thinking maybe a 5 channel amp for my music unless someone can recommend a decent priced 7 channel amp to push all 7 speaks
(i really am budget minded here, thats why i went with the infinity speakers i got back in like 2003.. i dont really like them but hey, it was a good price)
Either way i'm a little lost here and ot all sounded right with my denon but once i made a few changes it sounds all out of whack
Welcome to the forum, Mark!
The following comment makes me wonder a bit:
...i have tried every setting and i cant get the same deep push from this sub as i could before without dwarfing out my mids and highs.
Perhaps you are just saying that the Pioneer can't push your speakers as loud as the Denon, so you have to turn the amp on your sub (or subwoofer level setting on the Pioneer) down? If so, I get that. The first time that I read it, it sounded like you were powering the sub with the Pioneer.
Anyway, an amp sounds like a good upgrade for you. I have a Pioneer 1015 that sounded great by itself at normal volumes, but it was straining when I wanted to listen louder than normal. So, I got a two-channel amp initially. It took the load for the front speakers off of the Pioneer, so the Pioneer could more easily power my other three speakers.
Some questions:
1. When you listen to music, how many speakers are you using? Two? Seven?
2. What is your budget? You say that you are budget-minded, but it helps to have a price point to shoot for.
Depending on your answers, I might recommend that you go with a two or three-channel amp - it could save you some money, and it might take enough load off of the Pioneer that your system sounds great to you.
Hi, Welcome i would recomend the Emotiva XPA-3 and i have it so i can say that it is a very nice amp with tons of power (4ohm = 400 watts) for 2 channel. I try not to recomend things that i dont have or that i have not listened to so i feel safe with this and it is about the most affordable new amp that is of high quality. Hope this helps, it is worth checking out anyway.
http://emotiva.com/xpa3.shtm
Kirk
