Couple things I would say... THX recommends cloth over leather seating - I say do whatever is best for the room. Comfort and aesthetics play an important part.
I doubt the choice of door will play much into the acoustics below 1000Hz so that's not really an issue unless you pursue some of the more expensive doors specially designed for bass trapping, etc... Go with a ventilated door for sure on the equipment side.
Thicker, folded drapes on the windows will be a good thing to consider.
Include surround back (7.1) speakers if at all possible - or at least wire for them.
