Most of you guys have given me a lot of help on building my theater room
Im getting ready to go shopping on new surrounds
I need to get rid of these bipole surrounds this installer installed not my choice long story there lol some of you are aware of
I've narrowed down my choices to 3 options
1) PSA the MT-110SR
Pro's I love the mounting capabilities of these either flat on wall or they are vesa compatible so I can angle them any way I like
They have a compression driver like my beloved JBL studio 590's
Very sensitive I think 94db very dynamic a sealed design so wall placement is easier handle a lot of power so they can keep up with my 590's later I can ceiling mount them they are built with an angle like the SVS prime elevations which I think would make them beasts for atmos speakers down the road when I buy 4 more 590's for my 7 base layer
They are made to be crossed over with subs
Cons directional due to the horn can be compensated somewhat due to the ability to angle them with wall mounting flexibility
Option 2 HSU HB-1 or HC-1 horn loaded bookshelf or LCR speaker
Pros sensitivity at 92 an perfect match for the 590's handle a lottof power can keep up with 590's way way less expensive then the PSA
Great reviews
Cons directional going to be more challenging to wall mount ported so need some space off the walls
Option 3 HSU CCB-8
Pros superb off axis response I can place them between the rows and get probably the best proper coverage for both rows
sensitivity okay I think in full space 88db but they handle a lot of power meant to be crossed over with a sub great great imaging important for an atmos or dts based system which mine is
Can sound and image just as well up close or far way toying with the idea of mounting on ceiling when repurposed as well. Think with off axis imaging they could be repurposed as bad ass ceiling speakers
Cons challenging wall mount ported so space is needed not sure if these can work was surrounds? Need advice on that one although more expensive then the horn HSU still less expensive then the PSA
Both companies do exceptional customer service so tie there
Great warranties by both tie there
I think PSA has better trial period and offers free shipping so edge there
Room is 18 wide by 26 deep with a slant on the left wall to the door 9 ft high ceilings
Up front running 3 JBL studio 590's with 2 SVS PB 4000's
Pictures to give you idea of placement to help with speaker decisions
All ideas and opinions and alternate speaker options are greatly appreciated thanks guys!!!!!!
