Advice on a used amplifier or new...
WmAx
WmAx
Mani-aX said:
sorry if i broke the tables too badly here...
BTW, you should consider hanging some acoustical absorbtion panels to the sides and backs of your speakers at the 1st reflection points; no good can come from the short time early reflections that would result from the setup as seen in your picture.
-Chris
I
indcrimdefense
i have RF-7 fronts, and have used the following for power: nakamichi receiver, denon 2805, cary audio cinema 5, rotel 1080, krell showcase 5, & B&K ref 125.2, and still searching to see who makes the starting line up. best sound for music so far has been cary audio cinema 5 and the cary cinema 6 pre/pro. the cinema 6 lacked several features i wanted, but was a sweet set up for 2 channel & multi channel music. have also spent some time listening to RF-7's w/ a aragon pre/pro & aragon 3000 series amp, which was nice, but i thought lacked a bit when compared to the cary setup. best bang for buck so far is the B&K, which is a great amp for 800 msrp. it's not as clean or as detailed as the krell, and not as powerful as the cary, but also costs substantially less than either.
MacManNM
MacManNM
Is this for surround or are you just going to use it for 2ch music?
