Hi-
This question may seem dumb or rudimentary to some, but I can't wrap my head around it. I recently bought a Marantz SR8400. I'm completely happy with it...it's really great. But, I know that eventually, down the line, I'd like to own separates. What the Marantz allowed me to do was add an amp and then pre-amp/processor later as it has pre-amp outs. I can't afford to plunk it all down at once, so the Marantz seemed to offer me immediate satisfaction, as well as the ability to add/grow in steps.
But here's my question; what amps can I add to this? Meaning, would an integrated work? Can you adjust that amp to have the output handled by the Marantz? Or, do I need to get a straight up power amp? If so, would two channel work? Meaning, could I do a 2 channel that allows me to have beefier 2 channel listening, but then let my Marantz handle all others. Is a multi-channel required. And finally, what would be the minimum for a noticeable difference. I was looking at the Rotel RMB1075 (for multichannel) or the 1070/1080 if 2 channel will work. My Marantz is rated at 115 wpc while these only jump me up to 125-130, or down to 100 in the case of the RMB1075. I know that's not a sizeable increase, but I've read that receivers are usually rated generously and may not acutally be pushing that much...that even a dedicated amp at the same wattage would sound louder and cleaner. Is this true? I just don't want to step back, but also, I want to know what would work best in my situation. As a recap of that situation, I want to add and amp now (cause my budget is tight) then move to a processor later, using my Marantz as the processor/surround channel driver for now. Any help in straigtening me out would be greatly appreicated. Thanks.
