Hello everyone. Been lurking around these forums for a while and finally bit the bullet and created and account to ask for help. I will try to explain my situation the best I can, so I'm apologizing in advance if this gets a little long.
I got a vintage set of amp and tower speakers which holds sentimental value. I'm sure it is nowhere near 'high end' in audiophile standards, but I am very pleased with the sound for the most part. The amp in question is the Pioneer SA-610 and the speakers driven by it are a pair of Pioneer CS-656. I use them for both music and movies, basically any kind of multimedia. I also don't really like very loud sound, I never really turn the knob above 1/4th.
My only complaint here being the bass. Anything bellow 100hz starts getting lowered in volume, while at 65hz and bellow the imbalance really gets noticeable. I also ran some tests, and it looks like they can only reproduce sounds as low as 34hz, anything bellow is completely lost. The 'loudness' switch on the amp seems to alleviate the volume differences in the mid-sub range, but sound becomes a little too fake and 'boomy' while the deeper bass is still playing too low (or doesn't exist at all).
So, I decided I need to complement my setup with an independent sub, ideally kicking in at 100hz and bellow. But here is where I'm starting to get a little confused as to how to make this work. I would like to keep my tower speakers at full range, meaning I don't want to introduce any crossover cut-off for them. Is it possible to have a sub with - possibly - its own crossover control (active?) so it will only receive certain frequencies, leaving the other two speakers perform the same as they are now and not introducing more stress to the amp? Also, since this amp only has the good old stereo speaker connections, could I somehow connect the sub on the same outputs, using some sort of a Y-split gimmick, again without affecting the tower speakers? Finally, what sub would you recommend that would play nice paired with this setup? I'm not looking on anything really high end, just something that would fill the gaps of my current system and blend in without overpowering the rest.
Sorry if this is too long to read. I'm not very knowledgeable so I tried to be as specific as I can. Any advice would be really appreciated!
