protocols? Levels matched?
But, if you take someone out of the room, have a cup of coffee and send them back in and play a track of music on one particular amp and have them guess which it is, I agree this is very difficult to do, since you lost you reference point between what ever equipment you were comparing.
Is that what was done in that Florida DBT? Or didn't they use an ABX box and none of the 3 could differentiate under the ideal condition?
No, you are grasping at straws here
A subtle difference in A+B testing can be totally lost as time goes by and there isn’t that comparison.
Yes, it can but was not the case in that link, was it?
Also, if there are no differences in amps, why do professional writers, when comparing two amps side by side, mention one may have a harsh mid range, the other much better and tighter bass – all this going through the same pre-amp.
Oh, please, not the pro reviews
Which ones were you referring to? The ones in Stereophile? TAS? Which one? Can you point to one that used DBT protocol, levels matched and statistically significant results? Or they just used the sighted comparisons, no rapid switching as you brought forth above, and waxed eloquently having ZERO value. No, they are just BSing, selling, period, end of story.
Same can be said of the infamous NAD 3020, which annihilated the competition and became an overnight success due to its sound.
Oh, really? Where, when? How was this established?
I wonder if you removed someone’s Krell amp and replaced it a $300 Yamaha and they come back from a week’s vacation, if they would notice. I wouldn’t like to say no, and yet I wouldn’t go with yes either.
What kind of comparison is that?
