in the last 6 months, i have demoed 5-6 amplifiers, and all made a noticeable difference. i have demoed both 2 channel & multichannel amps, and therefore at times the receiver was powering the surrounds with a 2 channel amp powering the fronts. when i had a multichannel i used the receiver a pre-pro only, or briefly when i experimented w/ adding 2 surround rears it powered the surround rears. i have had zero problems adding a 2 channel amp to a receiver. i demoed a rotel 1080 earlier this year, in may i think, so my comments are slightly jaded by time. i had about at a 4 day demo, and the unit appeared new out of the box, so if you believe in break in the unit was not fully broken in. to date, i have demoed the following amps & they are listed in my order or preference; krell kav-2250, cary audio cinema 5, krell showcase 5, B&K reference 125.2, nakamichi pa-5II & rotel 1080. also had a several hour demo of aragon soundstage & 3000 series amp, can't remember if it was the 2 or 5 channel, in a dedicated listening room w/ the same type of front speakers that i have. while i have not heard it at home, i would rate the aragon behind krell & cary audio, and above or on par w/ b&k. other than the rotel, all were floor units at the dealer so were broke in. the rotel was my least favorite due to its brightness & sharpness, particularly with vocals. will say for classical it sounded fine w/ denon 2805.  keep in mind i have klipsch reference speakers, which do not mate well w/ all components, and they did not like the rotel gear i demoed at all (stereo pre-amp, amp & cd player). best bang for the buck for 2 channel amp was the B&K, it's not as smooth and clean as either krell or cary audio, but its a hell of alot cheaper. im buying the krell kav-2250 to power my fronts, as for the rest of system will have to wait & see. ask for a demo at home
