active sub help!!!!
TheFactor
TheFactor
factor i see your going for the ultra i think i will be aswell do you think it would be overkill for a 9ft by 6ft bedroom i did some measurements today it will fit but ill have to turn it side ways :D can you get a grill for it ?
I Dont think it will be a over kill for you because you can adjust your sub accordingly, also if and when you have a bigger area you'll bet set to . You'll definately have a ton of headroom for sure were your at, your going to be feeling the bass probably more than your going to hear it lol but your going to hear it for sure to lol . What finish did you get and i'll tell you if I hate you or not j/k :p:D Oh you do have a choice of a metal or fabric grill too as you probably already found out .
speakman
lol yea I went with black in the end as it will match the units I intend to buy this week
djreef
djreef
well just ordered the ultra from subsonic sounds for £1499 but i have to wait 4 week's as there sold out and waiting for stock form the states :mad:
....as you now prepare for the longest 4 weeks of your entire life. I'm in the same boat - been waiting for a couple of weeks for my SB12-plus to get finished, and delivered. Hopefully by Monday. It seems that SVS is trying to make to order a bit these days. The 'just in time' philosophy should work well for them in these tough economic times.
DJ
speakman
DJ
lol I know 4 weeks I was looking at the pb12 plus as well as the New PB12–Plus for but thought to myself i will only upgrade to the ultra anyway so might as well get the pb13 :p
TheFactor
TheFactor
Yup thats exacly What I should of done too........
TheFactor
TheFactor
Nice , what flavor did you end up going with , I meant finish ? :)
speakman
i seen yours factor and changed from TB ;) to rosewood i also got a pair SVS SBS01 bookshelf's:D
