Ethan Winer said:
It has been proposed that EQ can reduce ringing. In my experience it cannot. To back up my claim I have posted graphs showing the
RESULTS of a professional consultant attempting to do exactly this and failing. So I don't see why it's unreasonable for me to ask for proof that EQ can reduce ringing in practice, by a meaningful amount, and over a useful physical area. For all the research and theoretical technical papers out there, you'd think
somebody would have performed the simple tests I am asking to see!
Perhaps we should all let the topic rest? You have been provided with references to papers discussing the research that has been done on the topic of active correction. Your reciprocative sharing of the findings of others on this topic is commendable. Now, instead of jumping to conclusions about the work others have done (which you have not read and reviewed), having others provide you with "graphs" (as if that would "prove" anything - I have yet to see a graph truly "prove" anything), and generally contributing to the hostility over something quite insignificant in the grand scheme of things...why don't we just forget about it? If there's anything I've learned over the years, it's that no one can force feed you, Ethan.
You've got your mind made up on this and that's just the way it is. Fine. We get it and that's AOK.
Gene, I think we should let this one go - it is clear that we are not able to provide the proof Ethan requires. Therefore, there's not much use in and nothing to be gained from continued back-and-forth.
Of course, it should be noted that no one here is really saying you're wrong, Ethan—just under-informed, perhaps? There are plenty of folks that feel just as you do about active correction. And, in fact, for many situations I share those exact feelings and opinions.
However, let's just let this one rest, agree to disagree, and move on.
> This reminds me of the issues we had years ago with Jon Risch on exotic cables <
Are you really suggesting that bass traps and acoustic treatment are in the same snake oil category as exotic cables?
I don't think that is what Gene's suggesting. I believe he was simply making a comparison between your strong convictions, and those of someone else - a comparison that Audioholics readers can relate to.
I don't see why "how we hear" bass should be glossed over with averaging.
I think there is some miscommunication going on here. Again - perhaps we should let it rest since we are not all on the same page. A 1/12th octave display is, arguably,
more representative of how bass is heard. Nothing is being glossed over.
If a null that aligns with the frequency of a bass note really is 25 dB deep, then that's exactly how far down it will sound when that note is played.
Very few listeners would be able to listen to
anything and say, "Oh, that's 25 dB down." Also, 25 dB down from what, exactly? From a peak 10 Hz lower? Hardly a valid reference point. Finally, how a null is perceived cannot be fully understood unless the nature of the problem - modal, boundary-interference, loudspeaker, other? - is understood. And even then, it's still being
perceived, it is a subjective "thing," and it cannot be equated "exactly" to something objective like a difference in sound level.
In short, I would - for the third time - request a break from all this. People are starting to say (with all due respect) some pretty silly things here and it's not going to do anyone any good.
That's a difference of 11 dB over a distance of only four inches. And yes, I was surprised too, so I measured both places again just to be sure it wasn't a glitch. It was not a glitch.
Perhaps you should ask yourself why you were surprised...
> Check out Robinson and Dadison curves which well establish this point. <
This is why I'm such a strong proponent of empirical evidence rather than relying on theory alone. Since I have proven (above) beyond all doubt that the low frequency response can change substantially over very small spans, it's clear the theory needs to be modified.
The Robinson-Dadson curves are the results of experiments. They are not "theory." Check out Figure 2.1 (pp. 13) of Newell's book (
Recording Studio Design). Since Newell didn't provide them, I'd be happy to provide references if you need 'em.
Also, no one is arguing against low frequency response being position dependent. Rayleigh understood this over 100 years ago and it's his math that is used (in most acoustics texts that cover the subject) to derive the equations governing the spatial response of a room. There is no "theory" that says otherwise.
