A/V With Good Sound
U
u2generator
Hi,
I have a fairly large room (3200 cu ft) and in the market for a new (or at least newer) A/V. I have had my old 4 channel Pioneer for several years and am looking to upgrade. I don't really care about the newest doo-dad, just good sound. I don't even mind buying refurb (this is the case with my old Pioneer) or even used. I am in the market for 5.1 speakers, so this data point won't help. I have Bose 901's but will sell these soon. My room also has hard wood floors so I don't need a bright receiver.
Thanks for your replies,
TW
MDS
Despite what some people will tell you there is no such thing as a receiver that is 'bright' or 'forward' or any other adjective unless it is poorly designed. All of those terms apply to speakers and even then the sound is largely influenced by the room itself.
Pick the receiver that meets your needs for number of inputs, features, power, and ease of use tempered by your budget limitations (if any).
N
Nick250
Take approximately 65% of your audio budget and start audition speakers in that price range. Once you have settled on speakers then re-read MDS's post above on receivers and pick one out. Speakers first, receivers second.
Nick
audiofox
Given the volume of your room, you might also consider a lower cost receiver that has preouts and run a separate power amp (or amps), especially if you end up with inefficient speakers like Dynaudios or Thiels-depending on the SPL level you want to achieve, it may be difficult to get there with a receiver alone if you have power hungry speakers. I agree with the previous posts-focus on the speakers you want first, then look at your input/control and speaker power needs relative to your receiver and/or power amplifier components. Just as a point of reference, speakers comprise around 60% of the audio portion of my av system budget if I don't include my turntable/tonearm/cartridge/phono stage (adding those in makes it more like 40%). As for refurbs, many here (including me) have had great success with refurb or B stock units from Denon, Yamaha and other well designed lines of electronics.
Another thought-have you considered using your 901s for the surround channels? In my experience, it is not as important for the surrounds to "match" the front and center channel speakers, and the 901 reflecting design might work well as a surround speaker (especially for movies). If you can hang onto them until after you get your mains and center channel speakers, it might be worth a test to see how they sound-you can always sell them if you don't like the sound or how they integrate with your other speakers.
moverton
MDS
Nick250
Nick
Excelent advice for a practical person to follow. I might even run the ratio up to 80% now that we need to buy 5 speakers instead of 2.
