A/V Receiver Video Inputs
roryshea
<font color='#000000'>This might be a really dumb question, but is there a benefit to connecting my video equipment (ie DVD player) through my receiever as opposed to directly through my TV? If my TV already has a component input, what do I gain by running the DVD component out through the receiver?</font>
dis
<font color='#000000'>It could be argued that by going through your amp your increasing the amount of cables and connections and hence degrading the signal.
Personally I go through the amp only because I you switch between to components at the touch of a button.
In my case my TV has only one set of component inputs so it becomes a pain to manually switch cables when I use my xbox or standalone DVD player.</font>
steve
<font color='#000000'>roryshea,
I don't think you've asked a silly question at all. &nbsp;Actually, this question is quite commen. &nbsp;The answer is really dependant on your setup and your TV.
My preference is to minimize the number of connections and the number of cables I have to purchase. &nbsp;In Reference System 2, I connect the DVD Player directly to the TV. &nbsp;If your receiver/processor offers upconversion to component video, then it is definately beneficial to run all video through the unit. &nbsp;But if not, I'd go direct.</font>
