Our company does a lot of Plasma installations, especially in new constructions.
We mostly use Peerless and Chief wall brackets.
The Peerless PLA series is probably the best for this kind of installations and we use a lot of chief ceiling brackets for LCD/DLP projectors.
The PLA Peerless that you show on one of your pictures on your post, is probably a better choice for brick and masonry walls installations, because of the flat mounting plate.
I recommend for you to drill 6 holes equally spaced to accomodate the surface of the brick wall where the bracket is going to be mounted on.
We use mostly masonry anchors similar to these or masonry nails.
www.acehardware.com/sm-installing-masonry-anchors--bg-1283458.html
Mr.T
