A question about a center speaker
Shadowmonic
Shadowmonic
is a CSI25 Polk Center Speaker the best center speaker to work with two front Polk R50s and two rear surround Polk R15? im using a RXV563 Yamaha Receiver
Shadowmonic
Shadowmonic
lol I'm new to this and I just had a bunch of questions and i kinda posted some of them twice and some guys got mad at me i didnt cuss anyone out or harass anyone or anything
GlocksRock
GlocksRock
If you can find an older csi25, it would be the closest match for your R50s
http://www.newegg.com/Product/Product.aspx?Item=N82E16882290020
I used the csi25 and 4 R15's for a system I put together for my girlfriends mom and sister, paired it with a low end yamaha reciever and a Dayton sub-100 and for a system that cost about $550 out the door, it's actually pretty decent.
Shadowmonic
Shadowmonic
are the polk CSR a newer brand? and whats the difference?
GlocksRock
GlocksRock
I'm sure the CSR is newer, they weren't available when I had my R series polks, as far as the difference, I'm not sure, probably just made to match the newer R series speakers. I'm sure the guys at the polk forums would be better suited to answer those questions.
Just save up and get the best you can get, cause once the upgradeitis sets in, it's hard not to keep buying stuff... I started out with a low end Polk R series setup, and now I have top of the line def tech and SVS stuff, and it wasn't cheap, but what can I say, I'm an audioholic :D
Shadowmonic
Shadowmonic
ok so are you saying i should get the CSR or the CSI25? to go with my two R50 and R15
njedpx3
njedpx3
I just hit you with a bunch of positive rep points, I got you down to only one red chicklet.
Peace and Good Sound,
Forest Man
njedpx3
njedpx3
OP,
Glocksrock has provided you some excellent answers, I will accede to his better knowledge and experience concerning the Polk centers.
Forest Man
