A fool and their money... Locking banana connectors
jinjuku
jinjuku
Moderator
Exhibit A: WBT Locking banana connectors from Parts Express ($36 PER plug)
Exhibit B: Locking banana from Speakerrepair (#40 for 10)
BTW the pic from GLS is the old 'Generation 1' so what you are actually getting is the revised Gen2 stuff.
I normally don't associate Parts Express with such foolishness but on the flip side of the coin can't blame them for taking a chumps money.
These have been around for at least 10 years. The GLS and 3 or 4 other similar locking plugs are all knock offs of the WBTs, and yes, they do work identically :)
You know what's NOT good about them...? If the sides touch they short... I hate that, especially on receivers where the posts are tight.
markw
Form over function.
That's been my gripe about fancy bananas for years but the average consumer just gotta see all that gold plating they are paying for.
gmichael
gmichael
Gold locking banana plugs are cool, but when do the platinum cucumber plugs come out? I could get into those.
Same here, but I have yet to have this actually happen and I have been using plugs like this for years. Once they are locked in place, they won't be loose enough to tweak and touch each other. All they would have to to is make the sleeves non-conductive.
That has been my main objection to metal banana plugs all along. Why they can't just use binding posts with standard EIA spacing, I don't know. Fat fingers can't get in easily but if the binding posts have the plastic spacer, it doesn't matter. Unfortunately, the manufacturers place the posts so the dual banana plugs can only go into a pair of positive or negative, not one of each.
For dual banana plugs, I used Stinger, from AAMP of America. Reasonable and they work well.
gmichael
gmichael
Yep, sort of :) The only problem with those is the cheap plastic barrel often cracks. I've have some that are nearly identical. The tips are metal, but the metal doesn't extend all the way through the plug.
A more flexable plastic would help. A nice clear layer over the metal would work.
